how does one convert a 2d point to a 3d point in featurescript?
alan_1
Member Posts: 14 EDU
I want to give a single point on a flat surface as the center point of concentric circles and I want to be able to select an arbitrary point on each circle. Then I want to convert those to 3D space so I can use them for various 360-degree operations. I can generate a 2D point in an arbitrary direction/distance from the point parameter. However, I can't figure out how to convert that to a 3D point.
alan_1
I found mention of the planeToWorld() function here: https://forum.onshape.com/discussion/4565/guidance-on-planetoworld-and-auto-placing. I'm going to try it out.5
