Updated FeatureScript: PP-CapScrews v 4.0.1 has hex heads, low-profile socket heads, and more!
dave_cowden
Member, Developers Posts: 470 ✭✭✭
Hi, everyone:
A new version of PP-CapScrews is now available. Many new features (mostly user-requested) are included:
https://cad.onshape.com/documents/2d7e0a6b68c2039da4221ebc/w/06d0026261b3d9bb908f74a1/e/b92e2707bc8e8165e208a55e
Caution: This version is not reverse compatible with the prior version, so be careful upgrading existing documents to use it. It is best to use this new version for new documents.
Here are some screenshots:
New: Hex Heads, ISO and ANSI
When hex cap screws are countersunk, the default counter-bore diameter is the standard washer diameter
New: Thread Series are separated by course/fine for easier selection
New: Low-head socket cap screws ( ANSI and ISO )
- Added hex heads ( DIN 931/933 )
- Added Low profile socket heads ( DIN 7984 )
- Thread selection is now separated by course, fine, and xtra-fine, to make it easier to select the right pitch
- Fixed a couple of problems with ISO threads
- Added ISO M2.5 pitch
- Renamed from the feature SocketCapScrews to CapScrews, now that hex heads are included
2
I just tried to update the feature and received the following error message:-
Custom feature "Socket Head Cap Screw" could not be updated because it does not exist in the update version.
Also it looked like it wanted to update from the existing V3.2 to V3.1.1?
Cheers,
Owen S,
I didn't test updating a document that was already using an older version of the feature. I am surprised at the error message, I didn't think changing names would cause an issue. Screwing up the numbers might have, though.
As a side note thought, I am pretty sure that updating won't work, because the inputs to this version are not compatible with the old one.
I will test that, and if it turns out to be true I will just revision this version up to v4.0 hopefully making it clearer that it is not reverse compatible.
Sorry for the confusion!
Do you know what the behavior will be if the definition is not consistent with the old one? I'm pretty sure that will be the case here, because I needed to change things rather than just add new definition fields.
Is there a recommended way to introduce new versions that are 'breaking' changes? I screwed up the version number here, not thinking about that-- of course the standard strategy would just be to use a major version number to indicate that.
But I'm wondering, perhaps it is best practice to create a brand new document rather than create a new version when introducing non-reverse-compatible changes? IE, should I be making sure that users can always safely go to the new version, without 'thinking' about it? Or is it ok to rely on users to understand that upgrading might break things?
Do you guys have thoughts on that?
I also put in a caution in the note announcement for other users, until i know the upgrade works ok. It may be best practice to create new documents for breaking changes, we'll see what @ilya_baran thinks on that.
@andrew_troup v4.0.1 also addresses the typo you found, thanks for reporting that!
I've tried to upgrade again but still get the "Custom feature "Socket Head Cap Screw" could not be updated because it does not exist in the update version." error.
This time it's trying to go from V3.2 to V4.0.1
Cheers, Owen S.
In terms of breaking changes, upgrading the feature in the toolbar can't break part studios, so that's always safe to do. Updating features in existing part studios can break them (it's often not necessary though -- if a feature is working, why touch it?). I think what you're doing in terms of communicating "very" breaking changes with a major version is reasonable. From the user's point of view, for a complicated and important part studio, I'd recommend using the compare tool after the upgrade to verify that nothing important broke.
@owen_sparks , I think for now i'll keep version 4.0.1 as-is. Let me know how it works if you try to upgrade. As Ilya points out, the best practice may be simply not to upgrade features in existing documents, simply upgrade the toolbar and use the new version for new designs. I'll stick with that strategy until it proves not to be feasible.
Based on the comments from Ilya, i think i'll just accept that the new version just needs to work for new documents until a couple more releases. Are you able to get your documents back working again using the old version? I think i'm ok accepting that upgrading an existing, in use feature is trouble--but I dont want to leave you with no solution to at least get back to where you were...
However, I was able to install the feature script in the toolbar and can use it in new documents. Looks very good to me. Thanks for adding M2.5 and splitting up the metric list into coarse fine and xfine pitches. I also like the addition of the DIN/ISO norms in the name of the screws
Hex screws show a strange cylindrical section below the head. Is this a bug or a feature?
Regarding the errors you got: Are you using this link to open the document? I could not duplicate the errors you receive:
If you can duplicate, can you send me the link you used?
Regarding the bottom section, the cylindrical section is the face washer on the bolt-- meant to be a feature. For example, described here:
http://stsindustrial.com/wp-content/uploads/2013/11/DIN-931-Dimensions.png
I used the maximum end of the range, between 0.25 and 0.8 mm thickness, depending on diameter for DIN 931.
What DIN/ISO spec are you using where the washer is not present? Perhaps I need to include that as a separate series.
No problems with existing docs don't worry on that account.
Sorry I wasn't specific; the issue I'm having is with upgrading the button on the main toolbar not an individual instance in a feature list in an existing document.
I'd imagine I can delete this button from the toolbar and install a new one from your updated doc.
Cheers,
Owen S
Failed to load document for workspace. An internal error has occurred; support code 1ed7c58d3524bb9496e293df
Is that the correct doc. to find your latest released version?
Cheers,
Owen S
@ilya_baran , can you have a look at this document please to see if there is something wrong with it? I can open it fine, but Owen keeps getting an error. its weird.
I'll have a play later.
Thanks for writing it!
Cheers,
Owen S
Thanks for alerting us -- there was an issue (should be fixed now) with a small portion of our Europe region that caused your support code and some minor internal reporting issues that we uncovered that prevented us from being alerted sooner.
Thanks, the file opens now without issues.
You are right, I never noticed those washer faces on hex screws. Probably because I don't use them a lot.
thank you very much for your nice feature script.
I have on small question:
Could you automate and link the names of the parts your script builts to the feature name? So that every screw part gets a describing name and every similar screw part gets the same name?
This has been requested before-- unfortunately unless it has changed, this is not possible due to limitations with the Onshape API at this time.
So, I'll let you know if I can do that
https://cad.onshape.com/documents/9c5837c75180e1e8a46f3d78/w/5eba8e7b6a87d6038efb4b79/e/6562724c4b47e172580fcb19
As you can see I have just copy / paste the Onshape's Hole feature and create a few holes.
Then I created the drawing and add the hole callouts
