How to create a ring (jewelry) with a varying cross-sectional profile (varying height and/or width)
DavidPhillips
Member, Developers Posts: 8 ✭
I'm new to CAD/OnShape, trying to do as stated in the title. I am not sure if there is a standard way of designing a shape like this, but ideally I'd like to specify multiple profiles around the band of the ring (say, at 0, 90, 180 and 270 degrees) to sweep between (interpolating the shape of the resulting solid between each profile) along the path that the band defines (typically a circle). The problem is I understand that OnShape does not currently support sweeping through multiple profiles (just one profile that is used for the entirety of the sweep). Is there a solution to this problem, or perhaps a different way entirely that is generally used for constructing a ring model?
An alternative approach that I've dabbled in which may be the way to go is to sketch the side profile of the ring as a circle for the inner edge, and a spline for the outer edge to allow for arbitrary depth of the band (ie distance between the spline and inner circle). This encloses a surface between hte spline and circle which can then be extruded to produce a solid ring band (though I would then need to figure out how to vary the height of extrusion so that the both the depth *and* width of the final band can be customized...)
Thanks,
David
Thanks,
David
Clara.io Developer
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi @david_phillips715, yes what you describe is do-able. Welcome to the forum BTW.
(a) First up I'd recommend you get the multi-plane featurscript tool. If you've not used FS things before they're additional tools written in the native OS language by anyone who cares to, and are used to add custom functionality, and are pretty cool.)
(b) Draw a circle on a sketch and then use this tool to make new planes about this circle.
(c) You're correct the sweep uses a single profile, but a loft can use as many as you like. Hurrah. So put sketches on each new plane and make the profiles you wish on them.
(d) Loft through these sketches (as a solid) to create your part. The loft will create a smoth transition for you, but the more planes the more intricate you can make it.
(e) Lean back and bask in the glory of your design / post a screenshot here so we can see.
Oh and if you want the design to be symmetrical then it may be quicker to model just half of it, then use the mirror feature to instantly make the other half.
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
No problem, happy to help.
BTW did you accidentally "vote down" my answers or did someone think my answers were rubbish? :'( I find myself surprisingly upset to have received them! Grrr.
Cheers,
That is my work in progress.
https://cad.onshape.com/documents/665c0ed5ebd690d47908381b/w/8d731be1cdd8f44a59e9eede/e/0157ae2f40c73d8a1d0e4ec2
Take a look at Part studio 2, a small example of what you can do with configuration's
https://cad.onshape.com/documents/cb5ba6d3468bcb20b1ed913e/w/cf9836594bd912bfce6de8d2/e/a834ffc829659b3ce65a123b
