Using the Measure Distance feature script
When using the feature script 'measure distance'. I get an error message "did not regenerate properly. cannot resolve entities".
I am trying to measure the angle between two lines in a sketch. I get the same error selecting two points, a point and a line, etc.
I click the MD icon, type in a name, select the two entities and click the green check mark.
ilya_baran Onshape Employees, Developers, HDM Posts: 1,235
Guessing here (since you haven't shared a document) -- there are two selection boxes, "First entities" and "Second entities" -- after you select the first line or point, you have to click on "Second entities" and then select the second. The reason it is done this way is so you can measure the minimum distance between, for example, one point and the closest of several lines. Also, without a modification to the FS, you will only get distance, not angle.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc5
