Using the Measure Distance feature script
ron_zimmermanron_zimmerman Member Posts: 5
When using the feature script 'measure distance'.  I get an error message "did not regenerate properly.  cannot resolve entities".
I am trying to measure the angle between two lines in a sketch.  I get the same error selecting two points, a point and a line, etc.
I click the MD icon, type in a name, select the two entities and click the green check mark.
  • ron_zimmermanron_zimmerman Member Posts: 5
    Yes, that was it.  Thanks.
  • glib_kotelnytskyyglib_kotelnytskyy Member Posts: 23
    I'm trying to use the script. But I can't select any other entyty, but the solid. When I click on a point, or edge - the whole volume gets selected.
    @glib_kotelnytskyy they have changed selection priority, use right click>select other command or use the latest version of Measure value FS where body selection is temporary disabled untill this behavior be repaired
