Printing Dimensioned Sketches
james_alford
Member Posts: 17 ✭
God morning.
I have created a series of sketches showing all of the relevant dimensions. Is there any way to print these without having to create a separate drawing and adding the dimensions to the drawing again, thereby duplicating the work involved? The design is for a clock and there are well over twenty components.
Thank you.
James.
Thank you.
James.
Here is what I have found:
- Orient your model so the sketch you desire is normal to the screen
- Select Print from the Document Menu
- Select paper size and orientation
- Use the view menu to change the display to Hidden Edges Removed or Hidden Edges Visible to remove shading (if desired)
- Right click on your sketch in the feature list and select Show Dimensions
- Zoom and pan your model until everything you want printed is within the print limits box
- Click on the green check to make it so
I hope this gets you what you want.Sr. Director of Product Definition. UX and Support
Thank you. This looks ideal and looks good in preview. I shall try it tonight on paper.
Regards,
James.
