Printing Dimensioned Sketches
God morning.
I have created a series of sketches showing all of the relevant dimensions. Is there any way to print these without having to create a separate drawing and adding the dimensions to the drawing again, thereby duplicating the work involved? The design is for a clock and there are well over twenty components.
Thank you.
James.
    edited September 2016
    James,
    Here is what I have found:
    • Orient your model so the sketch you desire is normal to the screen
    • Select Print from the Document Menu
    • Select paper size and orientation
    • Use the view menu to change the display to Hidden Edges Removed or Hidden Edges Visible to remove shading (if desired)
    • Right click on your sketch in the feature list and select Show Dimensions
    • Zoom and pan your model until everything you want printed is within the print limits box
    • Click on the green check to make it so
    I hope this gets you what you want.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    You can also right click on the sketch as select Show dimensions and then print.
    Lou Gallo
    Sr. Director of Product Definition. UX and Support
  • james_alfordjames_alford Member Posts: 17
    Brian,
    Thank you. This looks ideal and looks good in preview. I shall try it tonight on paper.
    Regards,
    James.
