need help design adapter for tilt shift photography (nikon d90)
zafer_ali
Member Posts: 2 ✭
Greetings
I would like to 3d print 2 rings to be used as adapters for tilt shift photography . one of the rings would act like a fastener for the camera and the other would be the housing for the lens. A bellow (not 3d printed) placed between these 2 rings will act as a medium for tilt and shift.
The issue is i am not sure of the measurements for the nikon d90 model mount and AF Nikkor 50mm f/1.8D lens
This image outlines the rough design for printing
https://www.flickr.com/photos/22988179@N04/shares/2H6V5p
Thanks in advance.
Za fer
Thanks in advance.
Za fer
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
This is a CAD forum. I'm sure there are plenty of people that would be happy to help with designing your adapter, but it sounds more like you want someone to measure your lens and camera threads. You'll probably have better luck with that on a Nikon forum.5
Onshape, Inc.
this is the bellow i plan to use
http://www.biltema.se/sv/Bil---MC/Bilreservdelar/Chassidelar/Fram-och-Bakvagn/Styrvaxeldamask/STYRVAXELDAMASK-UNIVERSAL-SERV-2000037054/
