Why do dimensions and C/L refs. spontaneously turn orange (invalid)
in Drawings
Hello All
Does anyone else experience this frustrating issue in Drawings? On re-opening a Document and resuming drawings, I find occasionally that previously defined dims. and refs. become invalid, and highlighted orange.
Thanks
Michael
Thanks
Michael
Note that this action only updates drawing views, nothing else in the drawing or document, and does not check for updated links to other documents.
At times, the update might not work seamlessly and an added entity (a dimension, for example) may turn red because it might be broken (or dangling).
You can fix a broken dimension by clicking the grip point and dragging it to where it should be. This is perfectly normal, especially if the change to the part or assembly was significant.
Tips
Given that a drawing may need to be updated as a result of a small change in a document (see above), you may want to 'lock down' a drawing so the Update button will not highlight. Simply version the document: this freezes the drawing in its current state and you can then mark the drawing's state as Released in the version.
I should have been clearer in my original post, sorry! I am finding this to occur even in the complete absence of changes to the underlying parts.
You make a very good point about versioning, though.
Regards
Michael
