Why are drawings so un-responsive?
I'm having issues with the drawing workbench being very slow and unusable.
I've seen posts about this but they all seem quite old, is there anything I can do to make drawings more responsive?
Cheers,
Rob
Cheers,
Rob
1
https://cad.onshape.com/help/#webgl.htm?Highlight=system
If your system have good internet speed and above requirement then also it giving poor performance then you can open support ticket for this by using feedback tool to Onshape support team. they will definitely solve your problem.
Does Onshape specify a minimum machine (CPU speed, RAM, HD capacity, graphics card) requirements and also internet speed and browser (Firefox etc).
I have been watching the Hoffman Engineering Youtube videos ( Best Free CAD Program:...) which look very smooth. What could the spec of their system.
I live in the N.E. UK.
To ensure optimal GPU performance when using Onshape, browse the recommendations below and compare to your configuration.
Browsers
Onshape currently supports these tested and approved browsers:
Internet Explorer is currently not supported.
WebGL
Onshape requires WebGL. To ensure that you are taking advantage of the highest performing configuration, make sure your preferred browser has WebGL enabled. On Chrome, it should be enabled by default, unless your graphics card does not support WebGL (check the black list: https://www.khronos.org/webgl/wiki/BlacklistsAndWhitelists). On Safari or Firefox, you may have to enable it manually:
If you make these changes while running Onshape, simply refresh your browser for the changes to take effect.
Graphics cards
Many computers have more than one graphics card installed (GPU). Often, on Windows machines with NVIDIA graphics cards, Optimus technology is also involved, meant to optimize the workload between GPUs -- to assign the proper graphics card to applications needing a high performing graphics card and applications needing more battery life and lower performing graphics card.
If you do not have NVIDIA or NVIDIA with Optimus technology, you can skip this topic.
To get the most out of your graphics cards:
See https://www.khronos.org/webgl/wiki/BlacklistsAndWhitelists for more information.
Determine whether or not your computer uses Optimus technology:
Select System Information and then Components. If Optimus technology is present, it will be listed somewhere in the right column.
To make the NVIDIA graphics card the default GPU for Onshape, or rather, the browser you want to use for Onshape:
If this method doesn't work, see below for more options.
In a nutshell
You want to use your high performance GPU when an application (like Onshape) demands it. Having a management technology involved (like Optimus) doesn't always result in the performance you are hoping for.
If you don't know what your computer has by way of GPUs, you can download and use a utility such as Speccy (for Windows) or gfxCardStatus (for Mac) to discover what is installed on your machine.
You want to use the faster, discrete NVIDIA GPU (when available) for Onshape, always. For applications that don't require high performance graphics or require longer battery life, you can use an integrated GPU such as Intel's integrated GPU. To this end, assign the appropriate GPU to a specific browser.
Alternative
As a last resort, you could try to go into the machine's BIOS settings and switch off Optimus technology completely and run using the discrete NVIDIA GPU all the time. This carries serious risk, however, so make sure you know what you're doing here, or seek help before attempting this solution.
Additional information
More resources include:
