n00b needs help with design drawings
I used Onshape to design a mechanical puzzle and am happy with the prototype that I 3D printed. Now I want to give the design to a machine shop to have it made from aluminum.
Many of the machine shops I've spoken to are happy to take .STEP, .IGES, or other file formats to program their CNC machines. I can easily generate those files from Onshape but I need actual drawings so that I can discuss some of the design features and their tolerance requirements. I'm not a mechanical engineer so I have no training in GD&T and need help making the drawings. So my first question is where can I post a design drawing job? I think this is a couple of hours of work and I would expect to pay for it.
My second question is this. I want to engrave markings on the flat surfaces of the outside of the puzzle. I have .DXF files of the markings but I don't know if I should add them in Onshape or simply give the machine shop separate instructions on the size, the location, and the depth of the engravings. What's the standard practice?
Apologies if I've posted to the wrong forum - I'm new here!
Might be worth posting where in the world you are (as conventions vary) where you want them made, in what quantity and to what quality. 5 units from a good old boy down the road would be rather different to 10K units form China.
Good luck,
Owen S,
When you call out the dimensions try to reference from a point on the part that will be easy for the machinist to locate. For a rectangular part that might be the top left corner; for the face of a cylindrical part that would probably be the center. If you have inside radii in pockets, make the radius slightly larger than the common milling cutter sizes - say 0.270" rather than 0.250". That gets you a better finish at less cost. And in case you didn't know, never design any sharp (0 ° radius) inside pocket corners - to get those you need EDM which gets expensive.
If you post a screen grab of the parts, I'm others here could offer a lot more suggestions.
If you decide against doing it yourself and no one else offers, send me a PM and maybe we can work something out.
Yes, machine shops can open .IGES and .STEP files and read dimensions off but that doesn't let them understand where my tolerances are important, where they're not, or where the reference datum on the part is. So that's why I've concluded I need a proper design drawing and wishing I had the GD&T skills to do it myself.
I'm a little surprised there isn't a jobs posting board or something in the Onshape forums so I guess I'll go try to find someone through Upwork.
