OnShape Project Reboot: Question 2: Are we able to flip the normal on the sketch image?
Are we able to flip normals on the sketch images yet?
If I have a right view I want to trace and then I have a left view that I need to trace....how do I make them directional? So that they have correct opposite orientation when viewed together?
I would have same issue with front and rear views and top and bottom views.
Linked[in]
Onshape, Inc.
Flipping in the 2D editor was my work around but now I have three extra files under version control in my work flow.
I
Onshape, Inc.
With OS, you need to upload the files to your doc before even using it, so it is always under version control. I think in this case the marginal increase in overhead of 3 more tabs in the doc trumps the status quo.
Linked[in]
Lol. All that typing to deflect away from a perfectly well thought out enhancement request? What is wrong with asking to be to orient the sketch and use an original drawing? It's a reasonable request.
I can do it in other CAD systems. It was just that little last bit that is needed to make the function 100%.
A simole ole yes we plan on doing it by X release...or no its too small to be on our radar...is all I was asking.
Onshape, Inc.
