Crash Course on opMateConnectors
Dylan_StewartDylan_Stewart Member, Developers Posts: 107 PRO
Hello everyone, I've got another question for you all.
I am trying to get the hang of the opMateConnector function... What I am trying to do is to create a sketch and then place 2 mate connectors on the sketch. One on the top left side and one on the top right side.
The code I have thus far, obviously doesn't work, but maybe one of you could help me out.
FeatureScript 422;
import(path : "onshape/std/geometry.fs", version : "422.0");
annotation { "Feature Type Name" : "Mate Connector" }
export const mateConnectorTest = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Width" }
        isLength(definition.width, LENGTH_BOUNDS);
        annotation { "Name" : "Height" }
        isLength(definition.height, LENGTH_BOUNDS);
        var width = definition.width;
        var height = definition.height;
        var verticies = [
            vector(0 * inch, 0 * inch),
            vector(0 * inch, height),
            vector(width, height),
            vector(width, 0 * inch)
        var sketch1 = newSketch(context, id + "sketch1", {
                "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE)
        skLineSegment(sketch1, "line1", {
                    "start" : verticies[0],
                    "end" : verticies[1]
        skLineSegment(sketch1, "line2", {
                    "start" : verticies[1],
                    "end" : verticies[2]
        skLineSegment(sketch1, "line3", {
                    "start" : verticies[2],
                    "end" : verticies[3]
        skLineSegment(sketch1, "line4", {
                    "start" : verticies[3],
                    "end" : verticies[0]
        skSolve(sketch1);
        var origin = vector(0, 0, 0) * inch;
        var leftxaxis = vector(0, -1, 0) * inch;
        var leftzaxis = vector(1, 0, 0) * inch;
        var leftskplane = plane(origin, leftxaxis, leftzaxis);
        opMateConnector(context, id + "leftMateConnector1", {
                    "coordSystem" : leftskplane,
                    "owner" : qCreatedBy(id + "sketch1", EntityType.FACE)
        var rightxaxis = vector(0, 1, 0) * inch;
        var rightzaxis = vector(1, 0, 0) * inch;
        var rightskplane = plane(origin, rightxaxis, rightzaxis);
        opMateConnector(context, id + "rightMateConnector1", {
                    "coordSystem" : rightskplane,
Digital Engineering
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,402
    opMateConnector "owner" needs to be a solid body
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,178
    And you're passing a Plane into opMateConnector where it expects a CoordSystem.  You can construct a CoordSystem by using either coordSystem(somePlane) or coordSystem(origin, xaxis, zaxis).
    Awesome!!! I'm another step closer. Here is what I have so far... Now just how to place the mate connectors where I want them?
    FeatureScript 422;
    PROFILE::import(path : "52bad43b4d807a71d217f4c8", version : "3294fd4185a5bf53e878e646");
    export enum profile
        annotation { "Name" : "1" }
        F3en76Q1MqYHM44_0
        precondition
            annotation { "Name" : "Square" }
            definition.squareProfile is profile;
            var verticies = [
            var contextWithProfiles is Context = PROFILE::build();
            opMergeContexts(context, id + "add_profile", {
                    "contextFrom" : contextWithProfiles
            const profile = qCreatedBy(id + "add_profile" + (definition.squareProfile as string), EntityType.BODY);
            definition.entities = qSketchRegion(id + "add_profile" + (definition.squareProfile as string));
            var ownerPlane = evOwnerSketchPlane(context, {
                    "entity" : definition.entities
            skSolve(sketch1);
            var line2 = sketchEntityQuery(id + "sketch1", EntityType.EDGE, "line2");
            var lineWidth = evLength(context, {
                    "entities" : line2
            var midpoint = evEdgeTangentLine(context, {
                    "edge" : line2,
                    "parameter" : .5
            }).origin;
            var lineAxis = evAxis(context, {
                    "axis" : line2
            var linePlane = plane(midpoint, lineAxis.direction);
            opTransform(context, id + ("TopTransform"), {
                        "bodies" : profile,
                        "transform" : transform(ownerPlane, linePlane)
            extrude(context, id + "TopExtrude", {
                        "entities" : definition.entities,
                        "endBound" : BoundingType.SYMMETRIC,
                        "depth" : lineWidth
                        "coordSystem" : coordSystem(origin, leftxaxis, leftzaxis),
                        "owner" : qCreatedBy(id + "TopExtrude", EntityType.BODY)
                        "coordSystem" : coordSystem(origin, rightxaxis, rightzaxis),
    The profile is just a cube.
    Digital Engineering
    The coordinate system origin is what controls the world-space location of the mate connector.
    Okay, so I've tried placing different parameters in the coordSystem() and nothing seems to be changing the location of the mate... Is there an example or could you please show me how to change the location of the opMateConnector??
    Digital Engineering
    Where would you like your mate connector to go?  Vertices 0 and 2?
    Yes, just anything to get them in to a new location would much appreciated.
    Digital Engineering
    Ok, I changed the right mate connector to appear in a different place (on linePlane at vertices[2] in the local plane's coordinates).  The new addition is rightPosition.
    https://cad.onshape.com/documents/f1a8ef47a7624f874d0e07ab/w/0b375ed6f9452e936eb73f20/e/f908b7a6816575518888532e
    cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 213
    @Dylan_Stewart The link below is an example I put together for patterning mate connectors at vertices.  It uses the vertex location and opMateConnector to create them.  It's a good example of placing mate connectors.
    Mate Connector Pattern
