Crash Course on opMateConnectors
Dylan_Stewart
Posts: 107 PRO
Hello everyone, I've got another question for you all.
I am trying to get the hang of the opMateConnector function... What I am trying to do is to create a sketch and then place 2 mate connectors on the sketch. One on the top left side and one on the top right side.
The code I have thus far, obviously doesn't work, but maybe one of you could help me out.
FeatureScript 422;
import(path : "onshape/std/geometry.fs", version : "422.0");
annotation { "Feature Type Name" : "Mate Connector" }
export const mateConnectorTest = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Width" }
isLength(definition.width, LENGTH_BOUNDS);
annotation { "Name" : "Height" }
isLength(definition.height, LENGTH_BOUNDS);
var width = definition.width;
var height = definition.height;
var verticies = [
vector(0 * inch, 0 * inch),
vector(0 * inch, height),
vector(width, height),
vector(width, 0 * inch)
var sketch1 = newSketch(context, id + "sketch1", {
"sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE)
skLineSegment(sketch1, "line1", {
"start" : verticies[0],
"end" : verticies[1]
skLineSegment(sketch1, "line2", {
"start" : verticies[1],
"end" : verticies[2]
skLineSegment(sketch1, "line3", {
"start" : verticies[2],
"end" : verticies[3]
skLineSegment(sketch1, "line4", {
"start" : verticies[3],
"end" : verticies[0]
skSolve(sketch1);
var origin = vector(0, 0, 0) * inch;
var leftxaxis = vector(0, -1, 0) * inch;
var leftzaxis = vector(1, 0, 0) * inch;
var leftskplane = plane(origin, leftxaxis, leftzaxis);
opMateConnector(context, id + "leftMateConnector1", {
"coordSystem" : leftskplane,
"owner" : qCreatedBy(id + "sketch1", EntityType.FACE)
var rightxaxis = vector(0, 1, 0) * inch;
var rightzaxis = vector(1, 0, 0) * inch;
var rightskplane = plane(origin, rightxaxis, rightzaxis);
opMateConnector(context, id + "rightMateConnector1", {
"coordSystem" : rightskplane,
}); Digital Engineering
opMateConnector "owner" needs to be a solid bodySenior Director, Technical Services, EMEA0
And you're passing a Plane into opMateConnector where it expects a CoordSystem. You can construct a CoordSystem by using either coordSystem(somePlane) or coordSystem(origin, xaxis, zaxis).Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Awesome!!! I'm another step closer. Here is what I have so far... Now just how to place the mate connectors where I want them?
FeatureScript 422; import(path : "onshape/std/geometry.fs", version : "422.0"); PROFILE::import(path : "52bad43b4d807a71d217f4c8", version : "3294fd4185a5bf53e878e646"); export enum profile { annotation { "Name" : "1" } F3en76Q1MqYHM44_0 } annotation { "Feature Type Name" : "Mate Connector" } export const mateConnectorTest = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Width" } isLength(definition.width, LENGTH_BOUNDS); annotation { "Name" : "Height" } isLength(definition.height, LENGTH_BOUNDS); annotation { "Name" : "Square" } definition.squareProfile is profile; } { var width = definition.width; var height = definition.height; var verticies = [ vector(0 * inch, 0 * inch), vector(0 * inch, height), vector(width, height), vector(width, 0 * inch) ]; var contextWithProfiles is Context = PROFILE::build(); opMergeContexts(context, id + "add_profile", { "contextFrom" : contextWithProfiles }); const profile = qCreatedBy(id + "add_profile" + (definition.squareProfile as string), EntityType.BODY); definition.entities = qSketchRegion(id + "add_profile" + (definition.squareProfile as string)); var ownerPlane = evOwnerSketchPlane(context, { "entity" : definition.entities }); var sketch1 = newSketch(context, id + "sketch1", { "sketchPlane" : qCreatedBy(makeId("Front"), EntityType.FACE) }); skLineSegment(sketch1, "line1", { "start" : verticies[0], "end" : verticies[1] }); skLineSegment(sketch1, "line2", { "start" : verticies[1], "end" : verticies[2] }); skLineSegment(sketch1, "line3", { "start" : verticies[2], "end" : verticies[3] }); skLineSegment(sketch1, "line4", { "start" : verticies[3], "end" : verticies[0] }); skSolve(sketch1); var line2 = sketchEntityQuery(id + "sketch1", EntityType.EDGE, "line2"); var lineWidth = evLength(context, { "entities" : line2 }); var midpoint = evEdgeTangentLine(context, { "edge" : line2, "parameter" : .5 }).origin; var lineAxis = evAxis(context, { "axis" : line2 }); var linePlane = plane(midpoint, lineAxis.direction); opTransform(context, id + ("TopTransform"), { "bodies" : profile, "transform" : transform(ownerPlane, linePlane) }); extrude(context, id + "TopExtrude", { "entities" : definition.entities, "endBound" : BoundingType.SYMMETRIC, "depth" : lineWidth }); var origin = vector(0, 0, 0) * inch; var leftxaxis = vector(0, -1, 0) * inch; var leftzaxis = vector(1, 0, 0) * inch; var leftskplane = plane(origin, leftxaxis, leftzaxis); opMateConnector(context, id + "leftMateConnector1", { "coordSystem" : coordSystem(origin, leftxaxis, leftzaxis), "owner" : qCreatedBy(id + "TopExtrude", EntityType.BODY) }); var rightxaxis = vector(0, 1, 0) * inch; var rightzaxis = vector(1, 0, 0) * inch; var rightskplane = plane(origin, rightxaxis, rightzaxis); opMateConnector(context, id + "rightMateConnector1", { "coordSystem" : coordSystem(origin, rightxaxis, rightzaxis), "owner" : qCreatedBy(id + "TopExtrude", EntityType.BODY) }); });
The profile is just a cube.Digital Engineering0 -
The coordinate system origin is what controls the world-space location of the mate connector.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Okay, so I've tried placing different parameters in the coordSystem() and nothing seems to be changing the location of the mate... Is there an example or could you please show me how to change the location of the opMateConnector??Digital Engineering0
Where would you like your mate connector to go? Vertices 0 and 2?Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Yes, just anything to get them in to a new location would much appreciated.Digital Engineering0
Ok, I changed the right mate connector to appear in a different place (on linePlane at vertices[2] in the local plane's coordinates). The new addition is rightPosition.
https://cad.onshape.com/documents/f1a8ef47a7624f874d0e07ab/w/0b375ed6f9452e936eb73f20/e/f908b7a6816575518888532e
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
@Dylan_Stewart The link below is an example I put together for patterning mate connectors at vertices. It uses the vertex location and opMateConnector to create them. It's a good example of placing mate connectors.
Mate Connector Pattern0
