Negative Mold
shai_perednik
Member Posts: 56 ✭✭
I need to create a negative mold of this fan duct which will then be used with simscale to simulate airflow and improve the duct.
How can I create a negative of this shape? Any suggestions on where to start?
doc @ https://cad.onshape.com/documents/14f3d01d62b5237f728896c5/w/40e0afc950b8ca0dfecf9ef8/e/f3ea28b89020464ba125df5d.
Thank you!
Thank you!
Optionsbradley_sauln Moderator, Onshape Employees, Developers Posts: 373The best way is to extrude a box as a new part around this fan so that both openings of the duck line up with the box faces. Then use the boolean subtract tool to create your negative: https://cad.onshape.com/help/#booleanparts.htm?Highlight=boolean
*Make sure to check off "keep tools" so that you don't lose your part.5
Twitter: @bradleysauln
UPDATE. that worked. I had to sketch a box at the bottom and top of the duct, then loft between them to get the right shape.
Please update this thread with your progress on using Simscale for this, if you don't mind.
