Newbie question. How do I scale an object in Y and not X.
chris_dalby
Member Posts: 13 ✭✭
I have an airfoil section made up of 2 multi point splines. I want to change the % thickness of the tip airfoil. I cannot seem to find any reference to scale or resize that allows scaling of one axis and not another.
I know it's going to be a simple, starring me in the face, answer BUT..................
https://cad.onshape.com/documents/b5af05b5e59da6a48c2ff20d/w/dd3c994e215c5194c71b3989/e/ccb8884f22a2e0343c2c99a7
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,245
Here is a (FeatureScript) custom feature that will allow you to do a non-uniform scale. Just select the part to scale, the point to scale about and the scale numbers for x y and z.
https://cad.onshape.com/documents/ccbbbcd87f9c80f9650af745/v/d3f3849203d96becc718a958/e/634ccf554fae91db941806f5
See https://www.onshape.com/featurescript#start for a quick intro of how to use custom features.
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc8
Next, how are you generating the profiles?
if you are using one of the public custom features for reading in Csv data, you could scale the data or apply a factor in the custom feature. If you are using a custom feature to generate the sections, you could expand apon the code to generate the sections in any way that pleases you.
I hope this helps.
He is one of the two aeronautical engineers that work at Onshape (I am the other one
