Onshape suddenly reports WebGL is not enabled in Chrome. Is this a bug?
doug_curtis
Member Posts: 14 ✭✭
Have been using onshape for a good while with no issues. Suddenly today when I attempted to go into a document it responded
"It looks like your browser doesn't have WebGL enabled. Click here for more information."
After searching for what was going on, I have finally confirmed that WebGL is indeed enabled (Using chrome://gpu in the address bar, it shows WebGL is hardware accelerated). I even updated the graphics driver for my Nvidia 8500 GT. Granted it's an older card but as I said, it has worked fine up until today.
So is this a bug with the latest update to onshape? Need help. I can't get to my work at all.
ANY input is much appreciated.
Doug
Doug
Other questions :
1. What operating system are you on?
2. Are you able to access Onshape using another browser?
3. Did you recently update your browser?
Twitter: @bradleysauln
And no, the spinning cube did not appear so I concur that it is not an onshape issue. Maybe I will just uninstall chrome and reinstall and see what that does first. Not really wanting a bunch of browsers cluttering up my system.
I did make a bug report to google about the issue but I figure I will be lucky if I hear back at all.
Thanks for the suggestions. I will update this post once I have tried a reinstall of chrome and/or an alternate browser.
Doug
After additional research, I discovered that the WebGL feature of chrome is subject to just up and stop working for no apparent reason. I found several other posts in assorted places that detailed the same condition. Even when the settings show hardware acceleration to be enabled, it does not work. In most cases, google advised the user to do all the standard work (reboot, reinstall, update, etc. etc.) to no avail. Their final suggestion was to install chrome canary along side standard chrome as it was the latest beta version and would have all the most recent, yet to be distributed, updates. In other words, they don't know why it quit working and they are not going to put any effort into figuring it out.
To that end, I have installed firefox which works fine (maybe even a little better than chrome did) and will uninstall chrome. Don't have time to continue to troubleshoot something that isn't working when there is a working alternative available.
This fixes the issue for me, but I expect the Chrome developers to fix the issue so that we don't have to use this workaround.
" --disable_chromium_framebuffer_multisample" to the command line as it no longer seems to be working for me. I had to go back to using Firefox which runs fine but is not my default browser. If I find another workaround I will post it to this thread. Sorry about the false information, but I'm not sure yet why it stopped working.
Please remember that the fix is then only applied to this specific shortcut. If you have multiple shortcuts to Chrome (for instance both in the start menu and the desktop), it will only work for those you have edited.
Hope this helps.
Hope this helps and is an easy fix for you.
øyvind_kaurstad @benjamin_lambert It works good!
This solution worked for me.
benjamin_lambert said:
