STL import still far away?
Hi guys, I've been away from onshape for some time and just return to check if there is any plan yet to add STL import into Onshape.
I see no google results with the answer so I thought of asking it here, sorry if this is just another annoying question but it's my interest and will only consider moving to onshape fully when STL import will be implamented because I have so many parts saved as STL that I don't want to recreate in onshape.
Thanks.
Thanks.
cody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
@florian_ford The ability to import mesh data (STL, OBJ) was added with the September 14th update.
https://forum.onshape.com/discussion/4707/improvements-to-onshape-september-14th-2016/p1
6
Now I have to start learning onshape ...
