OBJ Import
![GWS50](https://profiles.onshape.com/17b48357c8992f1d2871016e8bf319961192f2905877ba02e05eef689cebc01d.png)
Please can you improve the OBJ import function. I have files that open in every other software that I have tried but all I get with Onshape is the document tab and a notification that the file has imported but NO tab (PArt studio) with the actual surfaces in it.
1
Please note that because of the nature of faceted file formats (such as STL and OBJ), that there are no surfaces and no bodies (these file formats are simply a bucket of triangles).
Here is a video showing a use case - https://forum.onshape.com/discussion/4707/improvements-to-onshape-september-14th-2016/p1
I hope this helps.
Why would this be?
Thank you - Philip . . .
I experimented importing several different OBJ and STL files the other day and had almost no luck at all. Seems like OS is being overly picky about what it will actually display as a mesh. I've submitted a ticket about it.
Also there's a shared document with some random files I'd tried to import in this thread:
https://forum.onshape.com/discussion/comment/23143
I don't have any scanned data to share at this time.
