how to unscribe ?
Unfortunatly, i have and will not have enough time to use ON SHAPE
So I prefer unscribe for a while ...
How can I do ?
Thank's
ALV
How can I do ?
Thank's
ALV
There is no need to unsubscribe if you are using the free plan. Your private data will stay private, and if you want to use Onshape again, you simply need to login.
If you are a Professional subscriber who needs to downgrade to the Free Plan you can do this directly within Onshape. Under your username, choose manage your account-->subscriptions. Your account will be downgraded in the next billing cycle. Similarly, your private data remains private, and you can upgrade at a later time to continue to create and edit the private data.
Hope this helps.
Darren
