Can't extrude sketch
Josy_LaJosy_La Member Posts: 82 ✭✭
edited November 2016 in Community Support
I imported a shape from cad and inserted into a sketch. Obviously the shape is not fully "closed" because I have no areas to select for extrude. Is there a tool in Onshape to check where loop is opened? The sketch is not simple and reconstraining it would take for ever.
  • Josy_LaJosy_La Member Posts: 82 ✭✭
    On a parallel issue... Why does Onshape screw up the original cad sketch? I looks to be imported perfectly as shown on tab. But at insertion in sketch sometimes fillets are inverted creating a weird shape.
    timrice: Can you tell me what dwg files should not contain when imported? I see that xref need to be binded but I'm not to sure about cad blocks behavior or any other features that may cause errors.
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315
    @Josy_La
    If you were to export a drawing from another program as a dxf then items like title blocks would be imported as well.
    Onshape, Inc.
