Issues with Generating Drawings
marshall_haasmarshall_haas Member Posts: 6 ✭✭
I am no longer able to generate drawings of my designs. When I click on 4 views or add drawings in manually I am getting nothing to appear. The other issues is that when I go back to existing drawings that were done before the updates, I am unable to select centimeters as a unit for my dimensions. Millimeter is an option but centimeter is not. My original drawings were all set to cm... just want to put in cm dimensions in my drawings.
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ marshall_haas,If possible please share the document we will look into the drawing generating issue.And at present Onshape drawing has only 'Millimeters' ,'Inches' and 'Feet and inches' option.
    You can raise a improvement request for this.Hope it ll be introduced in future updates.
