I Can't Export/Download Locally
I right click on the tab, but there's no option to Export.  How can I do it?
See the picture below for what I mean:
Thanks for the help!
  • Jason_SJason_S Moderator, Onshape Employees, Developers Posts: 222
    edited November 2016
    I can see you are collaborating with someone. Ensure sure you have export permissions from the shared dialog. If you do not have Export permission, ask the document owner to change it.
    If you do have export permission, there must be something in the parts list to export from the document tab. There needs to be a part or surface to export from the document tab. Meshes imported to Part Studios are not exportable. To export a sketch you need to right click on the desired sketch and select "Export to DXF/DWG."
    Support & QA
    @milton_skeel, You can also use alternate solution by following below step.
    Step 1:- Click on "copy to clipboard" option for that part
    Step 2:- Use paste tab option to paste that part studio in new document or new workspace
    Step 3:- You can find export option for pasted part studio
    Kindly refer below video for more detail
