question mark meaning
papawopapawo Member, Developers Posts: 206 PRO
what does a question mark means in FS coding?
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,253 image
    It's a ternary operator: https://en.wikipedia.org/wiki/?:
    Basically, if you type:
    var x = predicate ? 1 : 2;
    Then if predicate is true, x is set to 1, if it is false, x is set to 2, and if predicate is not a boolean, an error is thrown.
  • papawopapawo Member, Developers Posts: 206 PRO
    thank you. :)
