Vector coordinates help
 Lee_Hesketh
                    Member, Developers Posts: 148 ✭✭✭
Lee_Hesketh
                    Hello all. My mortise and tenon script is still a WIP and I have ran into yet another problem. I am using the corner of a rectangle as the reference point for an skRectangle() function. Suppose the coordinates of the corner are (-50, 50)*mm in the x-z plane, and I want to put a point that is 10mm across and 5mm down, I have a problem. This is because if I just say (-50,50) + (10,-5) using this corner, the point ends up here:
However, if I use the other corner with coordinates (50,50)*mm, I can't just do (50,50) + (10,-5) because the point ends up here:
How could I set this up such that it doesn't matter which corner is selected without using lots of if statements?
Thanks
Lee Hesketh
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
             mahir
                            Member, Developers Posts: 1,317 ✭✭✭✭✭
                    You could change the sign of your offset based on the the difference between the selected point and and center of the rectangle in question (Pc). You could use either evBox3d or evApproximateCentroid. mahir
 if(Xc-X0<0) deltaX *= -1
 if(Yc-Y0<0) deltaY *= -1
 P1 = P0 + (deltaX, deltaY)
 Or, if you have vector data for the other corners, you could just substitute the average of those points for Pc. You just need to know which way is the body.5
