Hi, I'd like to have a little help if possible. How can I compress a valve spring in a animation.
Werner
Member Posts: 3 ✭✭
Sorry if this is a silly question but I've only just started cad.
many thanks.
Optionsfastwayjim Member, OS Professional, Mentor Posts: 220 PROJust add the spring as the last feature in your model, and constrain it's height to a datum plane. Like this:
Here's the model: https://cad.onshape.com/documents/61172f79358c96abcc746e32/w/2fbcb82d13e727a1932e8919/e/89b66bda9719e9442b65c90c8 -
OptionsTimRice Member, Moderator, Onshape Employees Posts: 315Wow @fastwayjim very elegant! Over this summer I created a live spring that could be animated in an assembly tab but the hit to performance with such complex mate relations is not worth it in production environments. Take a look at the video here:
https://www.youtube.com/watch?v=lzSXddwwanc
Onshape, Inc.6
Linked[in]
The spring must operate in conjunction with valve and camshaft.in cyl head.If pos?
Linked[in]
Onshape, Inc.
