Hi, I'd like to have a little help if possible. How can I compress a valve spring in a animation.
 Werner
                    Member Posts: 3 ✭✭
Werner
                    Member Posts: 3 ✭✭
 Sorry if this is a silly question but I've only just started cad.
many thanks.
             fastwayjim
                            Member, OS Professional, Mentor Posts: 220 PRO
                    Just add the spring as the last feature in your model, and constrain it's height to a datum plane. Like this: fastwayjim
 Here's the model: https://cad.onshape.com/documents/61172f79358c96abcc746e32/w/2fbcb82d13e727a1932e8919/e/89b66bda9719e9442b65c90c8
             TimRice
                            Member, Moderator, Onshape Employees Posts: 315 TimRice
                            Member, Moderator, Onshape Employees Posts: 315 Wow @fastwayjim very elegant! Over this summer I created a live spring that could be animated in an assembly tab but the hit to performance with such complex mate relations is not worth it in production environments. Take a look at the video here: Wow @fastwayjim very elegant! Over this summer I created a live spring that could be animated in an assembly tab but the hit to performance with such complex mate relations is not worth it in production environments. Take a look at the video here: https://www.youtube.com/watch?v=lzSXddwwanc https://www.youtube.com/watch?v=lzSXddwwanc
 Onshape, Inc.6
Linked[in]
The spring must operate in conjunction with valve and camshaft.in cyl head.If pos?
Linked[in]
Onshape, Inc.
