Sketch constraint symbol?
bruce_williamsbruce_williams Member, Developers Posts: 842 PRO
edited November 2016 in Using Onshape
What is this sketch constraint symbol?  I found it on a forum discussion from last year...
www.accuratepattern.com
    emmett_weeksemmett_weeks Onshape Employees Posts: 29
    It's a quadrant constraint. It constrains a point to be coincident to an ellipse and either the major or minor axis of that ellipse. It can only be made by inference, dragging something to, or placing something on one of those points on the ellipse.
    shanshanshanshan Member Posts: 147 ✭✭✭
    I guess the symbol is for circular pattern of entities which was appearing during earlier Onshape version. In latest onshape version it doesn't show even the sketch entities are done circular pattern
    Yes - I saw that behavior.  Thanks for the response!
    I am not finding any documentation in help - can I find it under something else?
    next topic
    Your search for ""quadrant constraint"" returned 0 result(s).
