Sharing documents between standard and partner accounts
Member, Developers Posts: 8
edited November 2016 in Account and subscriptions
Is it possible to share documents between a cad.onshape.com account and a partner.dev.onshape.com account? This would be very useful in debugging documents with our partner app. As far as I can tell, documents/links shared from cad.onshape.com are tied to that domain and do not also exist on the partner.dev domain.
Clara.io Developer
  • Member, Onshape Employees, Developers Posts: 78
    The two environments (cad aka production and the partner stack) are completely independent and there is no ability to share documents between the two environments I'm afraid.
    You can certainly have a debug version of your application that is registered on the production stack but is never made public - then use that version of the app to assist in debugging a problem document that has been shared with you on the production stack.
    Director of API, Appstore, and App Partner Technical Support
  • Member, Developers Posts: 8
    Thanks Andrew, we'll go ahead with your suggestion. However, how would one use the private debug app in a production (cad domain) document if the app is not added to the public app store? (or is there a way to add it to the store so it is hidden to all but your own account or for all members of your team?)
    Clara.io Developer
