Exporting Drawings to AutoCad - Can't get the scale correct
I have followed the process for creating a custom drawing template given by Onshape but after exporting to DXF/DWG the scale is never correct once reopening in AutoCad?
  • justin_hough563justin_hough563 Member Posts: 5 PRO
    edited December 2016
    ADD:  The organization that I am working for draws everything 1:1 and then prints 8.5 x 11 sheets to communicate with the shop
    You get this hammered out?
      When OS creates a dwg I've noticed that it makes everything in model space and creates a sheet with a view-port that shows whats in model space. But the items in ms are scaled to the os sheet scale.
    You need to go into model space and scale everything by what the scale is noted on in the OS sheet.
