Elipse bowl shape
aaron_skidmoreaaron_skidmore Member Posts: 34 ✭✭
I want to create a elliptical "bowl" shape into a solid block. I can create a circular bowl shape as per below by a Revole/remove, but want the same for an elipse.
bowl.jpg 233.4K
    You can revolve/remove the same as a circle see gif below.
    1.gif 1.3M
  • aaron_skidmoreaaron_skidmore Member Posts: 34 ✭✭
    edited November 2016
    Thanks Dave, I fell a bit silly now asking, as the fix is so simply!!
