Easyway to Draft multiple faces
aaron_skidmoreaaron_skidmore Member Posts: 34 ✭✭
Hi have a model with embossed lettering that has many faces, I want an easy way to draft all faces without having to individually select each face.
face.jpg 263.5K
    With the draft command try a side view and window select across all the side faces, first clicking from the bottom rh to top lh corner. Ensure to only pass through the side faces
    edited November 2016
    @aaron_skidmore use the draft option in the extrude feature that you used.
