Maximum call stack depth (for recursive functions)
jason_bennett190jason_bennett190 Member, Developers Posts: 17
Hi,
My experimentation seems to have bumped up against a built in limitation, so I wanted to confirm what the maximum call stack depth is for FeatureScript. From a quick check of a few values, it seems to be somewhere around 1500 recursions of a recursive function that the "Maximum call stack depth exceeded" error pops up.
What number do you have the maximum stack depth set to?
Why did you choose that particular number?
  • john_f_carrjohn_f_carr Onshape Employees Posts: 74 image
    The maximum call stack depth is 1024, because that is a round number much greater than any call stack we expect to see.
