Generate sketch from part
Hi,
Is there a way to generate a sketch from a part, by defining a custom cut or projection plane?
bruce_williams Member, Developers Posts: 842 EDU
The 'Intersection' command does this. It is under the 'Use' command icon. Choose part(s) and the intersection of part(s) and sketch plane is created.
Another way to make relational sketch entities is to use the 'Offset' command. It is not necessary to first convert with the 'Use' command when the goal is offset curves.www.accuratepattern.com5 -
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
It's hokey, but a work around for that is to split the part with the sketch plane, use an intersect within a sketch on the resulting cut surface, then use a boolean to reunite the separate bodies.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/c3b358533cdb341de5650652
5
More, if you change the sketch plane, all is gone.
In fact, the Section View is close to what I'm looking for, but I didn't find a way to generate the sketch of the intersection... Is it possible? If not, it would be great to implement it (and not too difficult, I think)...
Is it possible to make such operations automatically using FeatureScript? I didn't dig yet into this powerfull feature...
