How do you put multiple parts into a drawing?
steven_carlson
Member Posts: 3 ✭
in Drawings
I have a part with multiple parts in it. When I create a drawing, it will only let me insert one part into the drawing. Is there a way to put all bodies into the drawing?
Optionsbradley_sauln Moderator, Onshape Employees, Developers Posts: 373The insert view dialog has an icon next to it to allow you to select other parts/assemblies: https://cad.onshape.com/help/#drawings-views.htm?Highlight=insert view
5
After that click right mouse button on Assembly 1 tab->select "Create drawing of Assembly 1" Drawing will be created for all the parts.
Twitter: @bradleysauln
Note: your blob of parts in the assembly can be rearranged to where you want them, then updated the drawing and the drawing should update to the re-arranged parts.
Do remember when you pull in a specific part the metadata for the drawing will pull from the part properties if you pull a part-studio or assembly the metadata will be pulled from the tab (either the part-studio or assembly) properties.
If you insert an assembly and the assembly BOM into the drawing you can use bubbles to number parts in the drawing that match the BOM table.
