Parts Drawing at 1:1 on creation
Jason_S Moderator, Onshape Employees, Developers Posts: 219
Parts will be inserted at the sheet scale. To change your sheet scale, right click in while space on your drawing and select "Sheet properties..." Change the scale to 1:1 and click Ok. Now every view afterword will be inserted at 1:1.
Good luck!
JasonSupport & QA6 -
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
Not sure of your exact use case, but don't forget that you can export any planar face as dxf/dwg at 1:1 (for plasma/laser/waterjet), without making a drawing just by right clicking on itPhilip Thomas - Onshape6
Good luck!
Jason
You just improved my work flow; so simple. Was getting profile dwg files via part drawings for CNC router cutting. Now, two clicks and done. No more deleting the template too.
