Mounting Boss FeatureScript
robert_morris
OS Professional, Developers Posts: 166 PRO
Hello all,
I've finally finished up this FeatureScript and thought some others may find it useful.
It's for making different types of mounting bosses in plastic parts. These are used for adding screws to plastic enclosures, mounting circuit boards, etc...
The script was based off of the Hardware Boss script by @NeilCooke. I added the capabilities for other types of bosses, so now you can do a Hardware Boss with counterbore and through hole for screws, Pin Boss for alignment/locating parts, and a Hole Boss for screw threads or locator pins.
The other modification I did was in how the bosses are located. With this script, the sketch points define the top of the boss. This is useful because you can use a single set of points to define the locations of the bosses for both halves of an enclosure, or all the mounting points for a circuit board.
Here is the link to the FeatureScript:
https://cad.onshape.com/documents/2972a375d9fd3b741d7cc02a/w/45408693c3984999d8c8ff22/e/403280a8c811319478bddf50
I've tried to have a look at the documentation but somehow it's a tad mullered. It looks like multiple pages are being displayed on one sheet.
This is in firefox. Can anyone else view it properly?
Cheers,
Owen S,
I just checked it here and it was showing up odd in Firefox for me too. I normally use chrome, so I didn't notice it before.
There was a hidden layer in the Illustrator file that for some reason stayed in the PDF export and Firefox decided to show it even though it wasn't supposed to.
I fixed the file and bumped the version of the document, so it should work fine now.
Thanks for the feedback,
@robert_morris
Just wanted to repeat my thanks for making it public. Having had a quick play with the feature I'm sure I'll be using it for real in the near future. It appears very easy to use, is robust and is flexible. Nice work sir.
@kori
(1) Thanks for helping with the pdf.
(2) I'm sure you're way ahead of me but this feature is a perfect example of where it would be beneficial to have icons available in FS. Both in terms of the icon used to start the feature (the "MB" button is lost amoungst other FS buttons) and also within the feature's form. It would be great for example when picking from "Hardware", "Hole" or "Pin" options to have small picture of what the feature looks like, or even the images from the PDF describing which parameter is which.
Great example of OS and FS and the benefit to the community.
Cheers, Owen S.
