Mounting Boss FeatureScript
robert_morris
robert_morris OS Professional, Developers Posts: 176 PRO
Hello all,
I've finally finished up this FeatureScript and thought some others may find it useful.
It's for making different types of mounting bosses in plastic parts. These are used for adding screws to plastic enclosures, mounting circuit boards, etc...
The script was based off of the Hardware Boss script by @NeilCooke. I added the capabilities for other types of bosses, so now you can do a Hardware Boss with counterbore and through hole for screws, Pin Boss for alignment/locating parts, and a Hole Boss for screw threads or locator pins.
The other modification I did was in how the bosses are located. With this script, the sketch points define the top of the boss. This is useful because you can use a single set of points to define the locations of the bosses for both halves of an enclosure, or all the mounting points for a circuit board.
Here is the link to the FeatureScript:
https://cad.onshape.com/documents/2972a375d9fd3b741d7cc02a/w/45408693c3984999d8c8ff22/e/403280a8c811319478bddf50
  • owen_sparks
    Hi @robert_morris, this looks very useful indeed.  Thanks for sharing it.
    I've tried to have a look at the documentation but somehow it's a tad mullered.  It looks like multiple pages are being displayed on one sheet.
    This is in firefox. Can anyone else view it properly?
    Cheers,
    Owen S,
    Boss.jpg 231.8K
    HWM-Water Ltd
  • michael3424
    michael3424 Member Posts: 785 ✭✭✭✭
    Looks fine to me in Chrome on a PC running Windows 7.
  • kori
    kori Onshape Employees Posts: 25 image
    I can see the issue in both Firefox and Safari.  The pdf looks fine in Chrome and Opera.  Downloading the pdf and opening it directly in the browser (i.e. without Onshape involved), the pdf has the same issue in Firefox and Safari, so it appears to be an artifact of the uploaded pdf itself.
  • robert_morris
    @owen_sparks
    I just checked it here and it was showing up odd in Firefox for me too. I normally use chrome, so I didn't notice it before.
    There was a hidden layer in the Illustrator file that for some reason stayed in the PDF export and Firefox decided to show it even though it wasn't supposed to.
    I fixed the file and bumped the version of the document, so it should work fine now.
    Thanks for the feedback,
  • owen_sparks
    edited January 2017
     Thanks folks, all good now.
    @robert_morris
    Just wanted to repeat my thanks for making it public.  Having had a quick play with the feature I'm sure I'll be using it for real in the near future.  It appears very easy to use, is robust and is flexible.  Nice work sir.
    @kori
    (1) Thanks for helping with the pdf.
    (2)  I'm sure you're way ahead of me but this feature is a perfect example of where it would be beneficial to have icons available in FS. Both in terms of the icon used to start the feature (the "MB" button is lost amoungst other FS buttons) and also within the feature's form.  It would be great for example when picking from "Hardware", "Hole" or "Pin" options to have small picture of what the feature looks like, or even the images from the PDF describing which parameter is which.
    Great example of OS and FS and the benefit to the community. :)
    Cheers, Owen S.
    HWM-Water Ltd
  • ry_gb
    ry_gb Member, csevp, pcbaevp Posts: 273 PRO
    Reviving this old thread. I'm finding the FS really helpful, but it seems like I'm running into a bug. Selecting the Rib option creates Ribs that are offset, if multiple holes are selected.
    Ramon Yip | glassboard.com
  • robert_morris
    edited December 2024
    Hi @ry_gb
    Thanks for reporting this. I'm glad you've found it helpful.
    I'm a little busy at the moment, but I'll dig into it as soon as I can and try to get it fixed.
  • ry_gb
    No rush! Thanks for replying. I was able to get around it at the moment by using Point Pattern.
  • robert_morris
    Hi @ry_gb
    I took a look at this, and unfortunately, I cannot reproduce the issue that you are seeing.
    I created a simple part and used all of the same values that you show in your screenshot, and the ribs are added in the correct locations. I thought it might be because you selected the diagonal construction line for the rib direction, but that worked just fine in my document too. See the attached image. I tried all the other edges from the sketch and base model as well. They all placed the ribs in the correct locations and orientations.
