Welcome to Feature Script - Modify to fSphere
I am playing with Cody's simple intro of 90 second FS to make cylinder. No problem with fCylinder and fCuboid.
When I try fSphere I get error -- Precondition failed (isLength(definition.radius, NONNEGATIVE_LENGTH_BOUNDS))
Here is the code -
Here is the code -
FeatureScript 477;
import(path : "onshape/std/geometry.fs", version : "477.0");
annotation { "Feature Type Name" : "My Feature" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "My Length" }
isLength(definition.myLength, LENGTH_BOUNDS);
// Define the parameters of the feature type
fSphere(context, id, definition.myLength);
What is the fSphere needing to work?
www.accuratepattern.com
William_Barron Member Posts: 5 ✭✭
Actually, it would be more correct to use NONNEGATIVE_LENGTH_BOUNDS instead of LENGTH_BOUNDS.
5
precondition
annotation { "Name" : "Radius" }
isLength(definition.radius, LENGTH_BOUNDS);
fSphere(context, id, definition);
I have a LONG ways to go.... Folks like you that help out on the forum make it feel even more possible to learn FS.
