Sub-assy distorts in parent assy
Henk_de_Vlaam
Member, Developers Posts: 265 ✭✭✭
I have ASSY BANKSTEUN VOOR in which the feet is fully constrained with the rod. It's not movable.
When inserted in ASSY BANK (fastened to the plate) then the feet is free tangential movable. So, the position as in ASSY BANKSTEUN VOOR is not fixed anymore.
How can this happen?
Henk de Vlaam
Henk_de_Vlaam
The problem is solved by removing the second Planar mate with the custom mate connector in and adding a limit of movement along the X-axis in the first Planar mate.
Henk de Vlaam0
