Use a variable in a boundSpec
Lee_Hesketh
Member, Developers Posts: 148 ✭✭✭
Hell again, how could I use a variable as the maximum value for a lengthBoundSpec?
Thanks
Lee Hesketh
Thanks
Lee Hesketh
There are 10 types of people in the world. Those who know binary, those who don't and those who didn't expect base 3!
kevin_o_toole_1
Onshape Employees, Developers, HDM Posts: 565
Technically, no: LengthBoundSpec's are computed statically (before any variables have values), so that the spec is constant for every instance of your feature.
I see two options.
The cleaner one is: Use a large max, then inside your feature, do a reportFeatureInfo if the value is above the MAX (explaining why), and change definition.length to MAX.
The other option is to add editing logic which changes definition.length to MAX if it goes above MAX.
5 -
kevin_o_toole_1
How about something like:var myMax = 20 * centimeter; if (definition.myLength > myMax) { reportFeatureInfo(context, id, "Length entered greater than calculated max " ~ toString(myMax) ~ ". Using max value."); definition.myLength = myMax; } // ...build your thing5
I see two options.
