Can you export a model in free trial version of onshape?
craig_fazekas
Member Posts: 2 ✭
its been awhile since ive used onshape, last time i used it was a few months ago, before the plan changes i've been reading about.
would like to know if i can still export to STL. when i go through the process, as i have before. and click download. the export window disappears... and nothing happens.
john_rousseau
Member, Onshape Employees, Developers Posts: 421
Hi @craig_fazekas. Please open a support ticket. The only restriction in the free version of Onshape is no private documents. You should definitely be able to export to STL.John Rousseau / VP, Technical Operations / Onshape Inc.5
