Detail View Not Working
peter_ryseck061peter_ryseck061 Member Posts: 1 EDU
My detail view works in all other places on my part, except the one spot I need it to work. Take a look:
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ peter_ryseck061 , Can you check it again? I had same issue with one of my drawing view, now it is solved.
    Still If you facing the issue,you can share the document with Onshape support and raise a ticket.
  • john_mcculloughjohn_mccullough Moderator, Onshape Employees Posts: 38 image
    Peter, this problem was caused by the corner of your isometric view border overlapping the part front view where you want to center the detail view. The fix for this problem was pushed to production a few minutes ago.
