Improvements to Onshape - February 8th, 2017
NeilCooke
Moderator, Onshape Employees Posts: 5,395
It's here! We can't keep you in suspense any longer - Sheet Metal is now available for all users! If you haven't seen the video below, watch it through to the end as it covers every aspect of Simultaneous Sheet Metal - editing a sheet metal part in folded, flat, and bend table view - simultaneously!
Please take a moment to try out these new features and improvements and let us know what you think!
Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
SIMULTANEOUS SHEET METAL
OFFSET DISTANCE
I know this one will make a lot of people happy! When creating an extrusion up to next, face, part or vertex you can now specify an offset.SWEEP AND LOFT ERROR FEEDBACK
If you are trying to create a sweep or a loft and there is a problem, like self-intersecting geometry, Onshape will highlight it in red.ENTER MATE VALUES
When you select or edit a Mate, you can now modify the dimensions on-screen to position your parts more accurately.DECIMAL PLACES
You now have control over the number of decimal places displayed in sketches, parts and assemblies.DRAWING DIMENSION HIGHLIGHTING
When you add a dimension in a drawing, the geometry you select now highlights.WATCH PART STUDIOS WHILE EDITING FEATURESCRIPT
You can now see if your custom FeatureScript feature is working as expected without having to leave the Feature Studio.CHANGE INSTANCE FROM WORKSPACE TO A SPECIFIED VERSION
When you derive a part from one Part Studio into another or insert a part into an assembly from the same Document, you can now specify if you want to use the part as it appears in the Part Studio and have it update at the same time, or you can specify a particular Version to use.REPORT FAULTY PARTS IN ASSEMBLIES
When you insert parts into an assembly, Onshape will now give you tooltip feedback if there is a problem, before you insert it and after it has been assembled.CHANGE THE FILENAME OF DRAWING EXPORTS (DWG, DXF, DWT, & PDF)
5
Once again Onshape you're making it all look easy, my sincere congratulations on some exceptional work. Beer-o'clock for all involved I'd say.
And to top it off a load of non SM updates too.
Thank you.
The use of 'main' version in local assembly, hopefully indicates it will be expanded for linked docs too
For those that don't use sheet metal can the icon's be turned off?
Great job
We are working on more flexible toolbars, including user configurable toolbars. Sorry about inconveniences in mean-time.
Great work to all involved, please keep it coming.
I think a great featurea could be to have possibility to work on flate view.
Thank you for your suggestion. Working in flat view is in our plans. Currently you can make selections in flat view for Flange and other sheet metal features. As always, adding this as an improvement request will help us prioritize our work and ensure that you are notified when the capability is implemented.
I've been using SolidWorks for over 10 years and have a few months experience with Solid Edge. SW is quite effective when it comes to sheet metal, SE I found to be a pain (but i am lacking experience with this). Its my opinion that Onshapes Sheet metal conversion is the most powerful that I have used, all the correct variables are present in front of the operator. No messing about there.
Next Weldments??
Linked[in]
We did that, as you can see in the next video: We have created a complete library of profiles and created a new FeatureScript extraordinarily useful to improve the creation of structures of aluminium.
https://youtu.be/aCjkPs2fGp0
The audio is in spanish, but i think that you can easily understand how it works
<unlock (thread)>
.. just trying to figure out the code to push this thread away from top and make room for new one
Patience Sir
OwS
I don't know if @NeilCooke or anyone else in Onshape is working in that.
As Onshape Partner's, We have created that library as a value-added service for our customers.
But I hope that, during the next few weeks, I shall be able to edit and improve the Beam FeatureScript and share it with all Onshape users.
