How can I export a sheet metal flat pattern to a dxf file, for work in a laser cut machine?
mauricio_hernandez
Member Posts: 10 EDU
Hi, I'm Mauricio from Colombia
Optionslana Onshape Employees Posts: 699Currently you need to create drawing of the flat pattern (RMB on it) which can be exported to DXF. We are working on a direct export from Flat view.5
