How do I align these sheet metal flanges?
SledDriver
Member Posts: 116 ✭✭✭
I've watched the preview video, which nicely evades this problem with an angled front to the box which means the flange is still a 90deg bend.
But what when the flange isn't 90deg to mate to a side flange?
I can't see how to do that.
https://cad.onshape.com/documents/af64487f57f7a4bc05a0b93d/w/8b56670c75204f5904e8c384/e/08a1e760702d942e57c6a666
Front and side flange do not align, nor will it even let me fudge the issue by manually tying in an angle in the table.
OptionsPahl Member Posts: 42 ✭✭Here I created the second flange feature. I unchecked Automatic miter and set the Bend angle.
Is that what you are trying to do?
6 -
OptionsSledDriver Member Posts: 116 ✭✭✭Aha! Thanks for taking the trouble to do that again.
Yes that technique works well! Excellent stuff.0 -
OptionsBen_Misegades Member Posts: 133 ✭✭✭There are certain aspects of that block that you've modeled in part studio 2 that aren't friendly for sheet metal model creation.
Have a look at my copy of what you've modeled. You can convert a lot of the faces into flanges, but not all, else you will have collisions in the flat pattern. That's likely why you're having conversion issues, not because of non-perpendicular faces.
https://cad.onshape.com/documents/381c3d41d72a24d86a6976e9/w/957eafa5cbb43538a75cb946/e/e1aa545b39cca16144f21a48
5 -
OptionsSledDriver Member Posts: 116 ✭✭✭Yup that works.
Thanks for your feedback on this. I was deliberately trying to find limits with this example, as this is often a good way to further understand how it works.
This has been very helpful.
Cheers,0
How about if you do each flange as a separate feature and then adjust the bend angles to what you want.
https://cad.onshape.com/documents/6a7e511a17384cab6b6eb2c6/w/c9f96754a5b1daa729668675/e/02fcdc6223fb7c3fbd3147f2
I ended up making each flange a separate feature and shorting them a bit. Not sure if this is what you had in mind or not but take a look at it and let me know.
Maybe someone can share a better way with both of us.
https://cad.onshape.com/documents/58a10eadc320e20f8d2404a0/w/59081fd60efe1314f6ebe32d/e/a1900ea3742b11d7175d9cb4
If you rotate your example appropriately, you can see the flanges are not aligned, and any attempt to make that piece would result in a very dodgy product indeed, exactly what you don't want from a quality cad solution.
Obviously its early days with this sheet metal stuff, but I was surprised it couldn't do this basic stuff. Also a little miffed that the example in the sheet metal intro video cleverly uses a blank which appears to be matching more complex geometry, but in fact it isn't - all the bends are still 90deg. Anything other than 90deg at this time and you run into problems it seems.
https://cad.onshape.com/documents/58a5085c3522310f74b3672c/w/fcc1b92700c5fe64462b87fa/e/aa91312120ce4e79e88d116c
Nice job! I like how you went about it. Thanks for sharing.
However, although it looks like you may have solved this example, yet again you have simplified the problem to a square cornered device with an angle only in one dimenstion.
My original problem was with compound angles. The corner was not 90deg, and the edges were not coplanar. This is a different and more difficult requirement.
https://cad.onshape.com/documents/629b129b3b5a7ce649ca9bd0/w/4591d821b7e8a9cae8097097/e/31e5c797b254a46091d09d7f
Surely there isn't a limit which says sheet metal sides have to be perpendicular to the base?
Have a look at Part Studio 2 in this document.
https://cad.onshape.com/documents/c37b593a65e7c4fdec03ec9e/w/15b4e318b4ad4dbe9ed63163/e/4d6e977099defe7891e99e3e
Cheers,
