Plane won't show up?
The plane I made won't show up when I am trying to put a sketch on it (only the one called "front" which was there). It is there when I'm not clicked into the sketch though!
  • lanalana Onshape Employees Posts: 761 image
    This sounds like the plane you've created is later in the feature history then the sketch you are editing. If the plane does not reference elements of the sketch, you can just drag it higher in the feature list.
