skSetInitialQuess
darren_13
Posts: 120 PRO
Hi need info about setting initial guess, what info do I need to give? I noticed that initial guessed are different lengths, what info is required for each of the constraint types? I want to use at least tangent and coinsident.
I looked at this link:
https://cad.onshape.com/documents/ed3b9a6ae6c5cd467bffb9b0/w/1d62d669e5575f39099131b7/e/e838735640fabde7c32c9989
But it doesn't seem to help me in understanding what the numbers mean.
Kind regards,
Darren Lynch
Kind regards,
Darren Lynch
Does anyone know anything about initial guesses for constraints? I tried doing what I wanted using numerical methods, i.e. iterating to find roots (for coincidence) and numerical differentiation to find gradients (for tangency). Although this has worked, and it was very good for my own development I did it knowing that there was an easier way. And it hurt my soul. I need this to further develop my parametric aerofoil script which allows the user to define more naturally any aerofoil shape they can think of.
Any hint would be great!
Kind regards,
Darren0 -
don't know how to use skConstraint, and i should notice that apparently feature script was not designed to maintain any advanced 2d sketching functionality. ie parametrization that works in 3D and allows to extract some differential characteristics of curves like evEdgeCurvature, curvatureFrameTangent/Normal/Binormal, evEdgeTangentLine, evFacetangentPlane don't has analogs for 2D geometry. so maybe you can try to generate your profiles like 3D curves?
Hi @konstantin_shiriazdanov, that's food for thought. Might set up a test script and see what I can do, Cheers!
Darren0
