order of iteration For loop for FACE query
theodore_peters
Member Posts: 15 ✭
I have seen the path method for getting the correct order of edges, is there a way i can do it for faces as well?
It creates the stairs, but as you know, it will not iterate thorugh the query in any specific order.
Any suggestions?
Any suggestions?
<div> var allfaces is Query = qEverything(EntityType.FACE);</div><br><div> var allfaces1 is Query = qCreatedBy(id + "mainsketch", EntityType.FACE);</div><br><div> </div><br><div> var count =0;</div><br><div> var evallfaces = evaluateQuery(context, allfaces1);</div><br><div> for (var faces in evallfaces)</div><br><div> {</div><br><div> count+=1;</div><br><div> opExtrude(context, id + ("extrude1"~toString(count)), {</div><br><div> "entities" : faces,</div><br><div> "direction" : vector(0,0,1),</div><br><div> "endBound" : BoundingType.BLIND,</div><br><div> "endDepth" : count*definition.rise</div><br><div> });</div><br><div> }</div>
(Looking again, if you're finding sketch regions, those aren't associated with individual ids, so your solution is likely the best one)
the reverse is true for direction vectors, if your vector is a length vector make sure you divide by a unit
