Changing orientation of imported SW parts
kirk_2kirk_2 Member Posts: 34
I tried the SW import today and checked the Y-axis up box.  The part imported properly, but the default isometric view after translate shows the bottom of the part rather than the top.  Is there a way to reverse the orientation (e.g., mirror the part)?
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 664
    You can use the transform feature to rotate your parts.  I don't know what your import looks like, but I would make a sketch on the top plane with a horizontal line to create an axis to rotate about.  Then I would start a transform feature, select all of the parts via shift+select in the parts list or by cross-selecting in the graphics area, choosing rotate then make the angle 90 or 180 degrees so that it looks the way you want it to.
    Jake Ramsley
  • mevalemevale Member Posts: 22
    edited March 2015
    The solidworks users are bad informed and worst oriented. wake up!!
    Normal CMM and standard CNC machines works with vertical Z.
    Thanks god OS reoriented the world as should be.
